First off I want to thank DJAnthony for his help but I was wondering if anyone else has used the fix of installing windows Vista to help the video freeze problem. I have the ge7400 video card in my lappy and I would kill to be able to use hardware acel.
Thanks
DJ Sean
Thanks
DJ Sean
Posted Tue 20 Nov 07 @ 6:46 am
I don't know your situation. What are the specs for your machine? What have you tried to do so far? Maybe there is help for you with XP. There are a lot of success stories with XP, so don't be so quick switch, if you don't have to.
Posted Tue 20 Nov 07 @ 7:35 am
Oh sorry here are my specs:
DV800t
intel duo processor 2.0Ghz
256 NVIDA GeForce Go7400
2.0 ddr2 sdram
80 gb 5400 RPM SATA HD
DV800t
2.0 ddr2 sdram
Posted Tue 20 Nov 07 @ 7:38 am
Does this card share it's memory? What have you done to try and fix this problem? If you have already posted this stuff, give me a link, so I can read it.
Posted Tue 20 Nov 07 @ 8:35 am
