How do i get the muisc to play on my headphones and to the speakers, so i can see at what point i want mix the song at.....
Posted Wed 14 Nov 07 @ 12:56 am
You will need a external soundcard for this or a Hercules console.
Jimmy b
Posted Wed 14 Nov 07 @ 1:17 am
Thank you
Posted Fri 16 Nov 07 @ 12:05 am
to be more precise you need a 4.1 usb external card for basic headphone preview
the mk2 is a good option from hercules as it gives u console edition included and a neat controler
Posted Fri 16 Nov 07 @ 12:41 am
Thanks Again...Do you know how much it will cost exactly.....
Posted Fri 16 Nov 07 @ 1:54 am
If you talking about the Herc dj console, and you live in the UK or Europe have a look here,
http://www.pixmania.co.uk/uk/uk/632682/art/hercules/dj-console-mk2-sound-card.html
If you just want a basic 4.1 soundcard then Creative ( which is a pretty good make ) do them from between 20-30 pounds. and the there is the Maya soundcard which has a good following on this site, which is about 70 pounds.
Hope this helps,
Jimmy b
Hope this helps,
Jimmy b
Posted Fri 16 Nov 07 @ 2:04 am
That's on that input....I live in the states though but i'll still check out that soundcard....
Posted Fri 16 Nov 07 @ 4:14 am
"TYPE-O"
Thanks on that input...But i live in the states...but i'll still check out that sound card.....
Posted Fri 16 Nov 07 @ 4:15 am
There you go dude,
http://www.guitarcenter.com/Hercules-DJ-Console-MK2-Dual-Deck-DJ-Mixer-103532479-i1155674.gc
And it works out about the same over the pond.
Jimmy b
Jimmy b
Posted Fri 16 Nov 07 @ 5:03 am
Annnnd you get the free version of 3.4 (home), then you get an upgrade discount.
Posted Fri 16 Nov 07 @ 5:47 am
