Ok I got my MAYA44 USB and things improve big time with better equipment. I haven't heard of other equipment so far so it seems a MAYA44 USB is a must.
As of now I would say TC vinyl is 98% perfect. Just some small stuff left.
- Floating BPM. As BPM is by estimation only (although very precise), it is better to set BPM to one value rather than have it float. Either the average over time, or the max BPM for instance like a volume spike indicator. It is no problem if two records are in sync while there BPM differs a little. We listen to sync anyway.
- Display right BPM in the Dvinyl console. I use the console to set loops and it would be wonderful if it displayed the right BPM.
Posted Tue 09 Nov 04 @ 5:06 pm
