Hello,
I have a laptop with a geforce nvidea 8400M G card.
After loading a second video and playing it, the first one would have video freezeups randomly (Like a 10 second freeze every 30 seconds) untill i loaded a new track in deck one, then deck two would start freezing. It seemed that it was always the OLD track that would suffer from the freezing issue.
This only happened with "Hardware Rendering" active under config
I also have a pc with the same problem but with rivatuner, the problem is solved now.
But on the laptop, the rivatuner can't find a database for the 8400M G: Cannot find the database for Forceware 156.10
Downloaded the Rivatuner v 2.06
How can I solve the problem with the freezeups?
Posted Mon 12 Nov 07 @ 1:18 am
Check the version of rivatuner you have and check what video driver it supports up to on their website. 2.06 supports. Perhaps upgrade to forceware 167.xx.
Posted Mon 12 Nov 07 @ 1:37 am
Thanks for your quick response.
Gonna check this out.
Posted Mon 12 Nov 07 @ 1:54 am
I downloaded and installed Rivatuner 2.06, but what do you mean with:Perhaps upgrade to forceware 167.xx. ???
Only thing I can say is when I want to open the database it says:
There are no databases for 156.xxx
Do I need to upgrade? and if so, how? (don't know how that works)
Posted Mon 12 Nov 07 @ 2:14 am
Yeah you just need to upgrade your video driver to one that rivatuner will support.
The best place I found for up to date drivers for laptops with Nvidia cards is here:
http://www.laptopvideo2go.com/forum/index.php?s=a140a38c42da54de5b99d9d9bbbb40a3&showforum=72
Good Luck
Good Luck
Posted Tue 13 Nov 07 @ 6:31 am
Thanks soundman69.
Gonna give it a try !!!
Posted Tue 13 Nov 07 @ 8:00 am
