Sorry if I'm being really think but i still havent managed to sort my headphone monitoring out.
Im also not 100% that i have wired everyting up correctly.
I have an amplifier which connects to speakers. I am currently using the Aux ports and connecting them to my hercules MK2 in output 1/2.
Im getting the sound out my speakers but i can sample any music using the headphone port on the front of the console.
It is probably somethin to do with the setings but i just cant work it out.
Hope some1 can help, thanks very much
Martin
Martin
Posted Fri 09 Nov 07 @ 5:26 pm
hi there are you using the V5 demo?
Posted Sat 10 Nov 07 @ 12:32 am
Full version
Posted Sun 25 Nov 07 @ 9:37 pm
please add your proedition serial to get the latest update
http://www.virtualdj.com/fusers/modifuser.html
Posted Sun 25 Nov 07 @ 10:53 pm
Sorry, it is the software bundled in with the MK2 so it must be the demo version.
Thanks
Thanks
Posted Mon 26 Nov 07 @ 7:24 pm
ok for the console software you should install the latest driver
then choose on sound options
DJ CONSOLE , Mixed mode
Posted Tue 27 Nov 07 @ 2:52 pm
Thanks very much for the help, i will giv it a go wen I get home tonight!!
How are the cables connected to the amplifier then? I am currently using the AUX port but i am unsure how to wire it up correctly.
cheers :)
cheers :)
Posted Tue 27 Nov 07 @ 3:13 pm
