I try to mix two mp3 and it records 7 seconds of the song and cuts it off i tried mixing 3 diffrent time same result .
Posted Wed 07 Nov 07 @ 6:18 pm
Go into vdj config, open options, look down the list and find Max Load set it to Always, and see if that helps.
Jimmy b
Posted Wed 07 Nov 07 @ 8:51 pm
what version do you have what is your pc spec?
Posted Wed 07 Nov 07 @ 9:25 pm
i have a 1ghz 512 ram computer with over 40 gigs free hard drive
Posted Thu 08 Nov 07 @ 8:23 pm
the thing with the max load didnt work altho now i get upto 60 seconds record time instead of 7
Posted Thu 08 Nov 07 @ 8:33 pm
i recommend you should get more ram and investigate if you can get a faster processor
as for best results vdj needs more resources
you can try to free up some by going to options and performances
and setting the slider to fastest , untick safe and overclock mode
and select autolatency
Posted Thu 08 Nov 07 @ 8:37 pm
