If a song is playing on deck A and I load a song onto deck B,
it should highlight deck B so that when I hit space bar, deck B
starts to play; and vice versa.
This works with XP, however I have found that with
Vista it does not work.
Anyone else see this? If so any cures?
Posted Tue 06 Nov 07 @ 9:41 pm
Hi bogart, me still using XP and mac OSX so can't comment on vista;
hmmm how abt creating the keyboard shortcut. it should werk don't they:)
Posted Wed 07 Nov 07 @ 1:57 pm
Thanks, I'll have to give that a try. One sys with XP is fine the other is Vista
and that is the one that doesn't work normally.
Posted Wed 07 Nov 07 @ 5:52 pm
Still no luck in getting this to work in Vista.
Only solution I can think of now is to uninstall VDJ and reinstall
to see if that will fix things.
Any other suggestions??
Posted Mon 12 Nov 07 @ 9:25 pm
hold that thought first mates, Maybe someone who use vista will post here soon n help ya:).. Sorry i can't be a help on this as i dun use vista os:(
Posted Mon 12 Nov 07 @ 9:38 pm
Mine works fine on vista. As a matter fact, I'm in the process of setting all my hot cues and goto buttons now.
In config.. headphones set to ON LOAD
shortcuts - deck control - play/pause - <spacebar> on focus deck
Does the <P> work for play/pause currently as it should?
Posted Tue 13 Nov 07 @ 12:05 am
Strange, but today it is now working. Changed skins from vmix 1.2 to the new one and
it is now working. Went back and forth between the 2 skins and all is fine now.
I doubt it was the skin though. Possibly some quirk in vista.
Thanks
Posted Tue 13 Nov 07 @ 9:26 pm
Glad u sort that out mates :)
Posted Tue 13 Nov 07 @ 9:29 pm
Thanks.
Wish I could say I sorted it out, but it just seemed to happen.
Strange how things do that.
Posted Tue 13 Nov 07 @ 9:37 pm
bogart wrote :
Thanks.
Thanks.
I took care of it for you, but keep it on the down low. I don't want everybody to know.
Posted Tue 13 Nov 07 @ 10:13 pm
lol
Posted Tue 13 Nov 07 @ 10:40 pm
bogart wrote :
Thanks.
Thanks.
You are one sick puppy!! (LOL)
Posted Wed 14 Nov 07 @ 7:15 pm
