After upgrading to rev 5 all the clips in the clipbank have disappeared. I reloaded all the clips and after rebooting the program, they disappear again. Happens every time I reboot the program...they just won't stay loaded.
Posted Mon 05 Nov 07 @ 2:46 am
Did you down load the new version of the clipbank? Delete the 3 clipbank files and install the new version.
Posted Mon 05 Nov 07 @ 3:28 am
No didn't download it but just did. Where are these 3 clipbank files you talk of? I can't seem to find them. I never used the old clipbank files.
I use Ambient videos that I ripped from my Promo Only DVD's. They worked fine with the last rev.
Posted Mon 05 Nov 07 @ 3:46 am
new improved clipbank :
http://www.virtualdj.com/addons/videoeffects.html
Posted Mon 05 Nov 07 @ 4:24 am
I got it.....thanks everyone.
Posted Mon 05 Nov 07 @ 4:28 am
Try C:\Documents and Settings\My Documents\VirtualDJ\Plugins\VideoEffect. Delete the clipbank files (3), and install the new plugin, then run.
Posted Mon 05 Nov 07 @ 5:57 am
Does anyone else have problems with .avi files in the new clipbank? Mine either play at a slow frame rate or not at all. Step back to 1.1 and all is well.
Posted Wed 07 Nov 07 @ 8:09 am
Only mpg file work fine at all, the avi and mov files have some problem.
Posted Wed 07 Nov 07 @ 9:23 am
