Everytime i use my cdj 800 when i set them up for time code the signal goes from 100 to 50 to 30 it does not stay at 100% what can i do to fix this problem i am using the time code file for cdj players from your site..
Posted Sun 04 Nov 07 @ 12:26 am
are you using the mk2?
if so check this
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
but choose timecode cd instead of vinyl
if so check this
Posted Sun 04 Nov 07 @ 1:51 am
The cdj 800 mk2 with serato sl1 box
Posted Sun 04 Nov 07 @ 2:29 am
alighty
how large is your timecode signal are you using the pro timecode?
Posted Sun 04 Nov 07 @ 2:56 am
