I’m using a 12” Computer monitor for karaoke monitor but I’m unable to connect to the bar TV’s.
I would like to change to a 9 to 10 inch Flat LCD TV for karaoke monitor unfortunately I’m having trouble finding anything affordable except this one. http://www.target.com/Haier-TFT-LCD-TV-KXT7020BK/dp/B000H3DQT2/qid=1193923438/ref=br_1_1/602-1808340-7470258?ie=UTF8&node=10775241&frombrowse=1&index=tgt-mf-mv&rank=price&rh=&page=1
Any Leads
Thanks
Any Leads
Thanks
Posted Thu 01 Nov 07 @ 2:43 pm
Why not just use another computer monitor? What you use will not make it any easier to hook into the bar TVs. If you need output uoptions, try this: http://sewelldirect.com/pc-to-tv.asp
Rusty
Rusty
Posted Thu 01 Nov 07 @ 4:11 pm
Rusty
Rusty
Thats a great option and it's small but I would lik to try not to add any more hardware to clutter my road case.
Posted Thu 01 Nov 07 @ 4:59 pm
also that unit is usb powered i would rather have one with a power supply
Posted Thu 01 Nov 07 @ 6:37 pm
True rockinrossco, but it's a way to go if I can't fine a flat tv for cheep. The moitore dosnt need to be of great quality eather. It's just for the singer to read the work.
Posted Thu 01 Nov 07 @ 7:47 pm
I use a flat screen 10" tv / monitor that I got for 70.00... it has Svideo, RCA, F-Cable and all I need is a adapter for HD connect. Check out your local electronic center and deal on a floor model. Find a young person, they generally don't care what price they give.
Posted Thu 01 Nov 07 @ 8:22 pm
I've bean looking unfortunately around these parts they only have 15" +.
My only other option is to order online.
My Video Card is a Sapphire Radeon X1600 PRO PCI Express 512MB DDR2 Video Card w/TV-Out, DVI & VGA
Posted Thu 01 Nov 07 @ 8:55 pm
