I am Looking to Build a new system What Mixer & controller works the best with virtual DJ so i can do audio & video mixing
Posted Wed 31 Oct 07 @ 2:06 pm
Couple of combinations work well.
Compleatly midi or mix system.
Mix system1 : Standard mixer & DMC2 from numark. Good controller that was developed for NumarkCue/VDJ has video and audio crosfade buttons built into the controller and a mapper avail to PRO users.
Mix System2 : Midi mixer such as NUO4 with Timecoded Vinals/CD's for Turntable guys.
Midi System : Numark Total Control with DJ i/o soundcard. No need for much else as the total control will handle most fuctions and the crossfader can be linked to do both video/audio at the same time. The I/O sounds good appearently From Guys who own it.
Other Controllers Are avail but not Compleatly supported at the moment.
Posted Wed 31 Oct 07 @ 2:23 pm
how does a DAC 3 work with Virtual DJ
Posted Thu 01 Nov 07 @ 10:50 pm
Works quite well
There is an extended mapper available for PRO users in the download section that really makes the controller come to life.
But it's only avail for FUll users ;(
Posted Thu 01 Nov 07 @ 11:16 pm
I've had both the DAC3 and the DMC2, DMC2 in my opinion is far better. I use video almost exclusively and the DMC2 just does it. Mixer this end is the Pioneer DJM3000, I love that too.
Posted Thu 01 Nov 07 @ 11:52 pm
I 'would' totally put a plug for the Denon HC4500 as a controler here if it were supported by VDJ!
But it isn't yet...
Side note to Denon and VDJ:
Is it supported yet... How about now...
(in the mean time the 4500 makes a pretty paperweight)
But it isn't yet...
Posted Fri 02 Nov 07 @ 2:54 am
Is there an extended mapper available for the Hercules MK2?
Posted Fri 02 Nov 07 @ 6:45 am
Yes there is:)
Posted Fri 02 Nov 07 @ 6:50 am
What exactly are the differences by using this mapper vs. unmapped? All the buttons on the Hercules seem pretty well in control of the VDJ interface just as plugged in via the USB.... ??
Posted Fri 02 Nov 07 @ 4:31 pm
Its ur preference;)
Posted Fri 02 Nov 07 @ 7:31 pm
But is there a way of actually seeing the possible improvements/changes from using the mapper?
Posted Wed 07 Nov 07 @ 12:48 am
