I recently upgraded to VDJ version 5. Since the upgrade, I can no hear the song that is playing when I switch the PFL to the other channel, In the previous version I was able to hear both channels in my headphones and preview the mix before playing it live (to ensure the beats matched). I am using a DJ IO and I have the headphones connected directly to the DJ IO. In the sound set-up, I have the following:
Inputs - None (I am not using TC vinyl)
Output - Headphones
Sound Card - ASIO Driver (latency - fast - I have tried latency at normal and no difference)
ASIO driver - Numark USB audio device
Output Channels - Master : Chan 1 & 2 Headphones : Chan 3 & 4
Please provide any help. Thanks.
Output - Headphones
Posted Sun 28 Oct 07 @ 6:21 am
the dj io is not an asio device choose 4.1/5.1 instead
as card type
as card type
Posted Sun 28 Oct 07 @ 11:52 am
The documentation that comes with the DJ IO says to use the Asio setting as soundcard. Further, when using the 4.1/5.1 setting, the DJ IO is not even an option and sound comes out of the laptop speakers, not the headphones. Can someone please provide some help. Thanks in advance.
Posted Sun 28 Oct 07 @ 4:25 pm
my bad , i confused it with another card
you do indeed need to choose it as an asio
http://www.numark.com/stuff/contentmgr/files/a35ff49383237f19e60421b4a67a7d54/file/dj_io_quickstart__v1.3.pdf
have you downloaded the latest drivers for this unit?
http://www.numark.com/content5113.html
Posted Sun 28 Oct 07 @ 4:33 pm
Did you load the driver CD that came with the DJ i/o before hooking up the DJ i/o? If not it does act oddly, you might want to restore to a previous date install the CD, and then hook up the i/o. Try that and see if that works.
Posted Sun 28 Oct 07 @ 4:37 pm
Updated the driver and had run the set-up CD before plugging in the DJ IO and I am still experiencing the problem. Any other ideas guys?
BTW - Thanks for the help so far.
Posted Sun 28 Oct 07 @ 5:16 pm
