Strange,
When I'm played videofile (vob) on my computer at the left deck, I see the videoclip.
When I play at the right deck a videoclip and put the slider to the right, I only see a black window.
BUT....when the right deck is playing with a black window, I put a videofile in the left player, then within a second the black window changed to the videoclip normal screen.
How do I solve this, because it looks like that the right player only works when I put a videofile in the left player while the right deck is playing.
Posted Sat 27 Oct 07 @ 9:20 am
what version do you use?
what is your spec?
what is your spec?
Posted Sat 27 Oct 07 @ 1:30 pm
I'm using the 5 rev 5 VDJ.
It doesn't matter wich skin I use.
The videocard in my pc is a geforce 6200 LE
Microsoft Windows XP Professional
2 gig ram
Amd Athlon 64
3700 + Hz
On my laptop I don't have this problem.
But I have hickups with playing vob files on my laptop with a Feforce 8400M G videocard (256 dedicated) and 2 gb internal ram.
I don't have hickups on my pc, but the problem on my pc is that I have a black screen when I play the videos at the right deck.
(maybe it isn't possible to play the vob files and mix them on my laptop without hickup problems)
If somebody can help me to get rid of the hickups on my laptop, then I really like to use the laptop.
Otherwise I need to know how to solve the black screen problem on my pc .
Best regards,
Anthony
2 gig ram
Amd Athlon 64
3700 + Hz
Best regards,
Anthony
Posted Sat 27 Oct 07 @ 1:51 pm
