Topic: Broadcast in local network problem
When i broadcast from my computer VDJ uses my public IP but older versions my static IP. How can i modify the broadcast IP from public to local?
THX
Posted Fri 26 Oct 07 @ 6:40 pm
I read that already... but i cannot use default setting because it shows me the public ip.
5.0 now
It worked with v3.0... but since then it doesn't work.
do you own a router?
please add your serial if you own vdj
https://virtualdj.com/fusers/modifuser.html
if not please support this program if you like it by purchasing it
i hope to see you with us soon as a pro user.
