Hi every1.
When using loop record i find that sometimes the max volume isnt loud enough when i play back during a mix. Ive turned dthe gain up on the songs and recorded but that doesnt work.
Any way out of this1?
Posted Sun 21 Oct 07 @ 12:38 pm
B-u-m-p
There better not be a really easy answer to this one.... i dont think there is.
Posted Tue 23 Oct 07 @ 11:59 am
what i do if encounter this, i would record it in sound forge or any audio editing program, edit it then put it in the samples for looping.
Posted Tue 23 Oct 07 @ 4:10 pm
not a bad idea, i will consider that if i cant do it in virtual dj, i say its the only way. cheers.
i looked in the manual and i couldnt find anything. dam why cant you record loops and have the sound recorded, be controlled by the gain as well!
Posted Fri 26 Oct 07 @ 3:39 pm
The answer is in the saound card you are using. If you get the gigaport ag soundcard you can use the 3 line out setup.
line 1= deck A
line 2= deck B
line 3= samples
then you will be able to play the samples on a deperate line with its own gain and eq (on the external mixer)
line 1= deck A
line 2= deck B
line 3= samples
Posted Thu 29 Nov 07 @ 12:00 am
