How do you get the samples from this website into VDJ.
I use firefox and it downloads them straight to my Desktop, but I don't know how to move them from there. Do you just copy and paste??
Jimmy b
Jimmy b
Posted Thu 18 Oct 07 @ 7:20 pm
Cut and past to the correct folder
Posted Thu 18 Oct 07 @ 7:36 pm
OK Jimmy, its not hard..but I am going to use pictures...
Open the sample field in the browser by clicking on the icon, red arrow and pointer on left..
Next click on the sample bank you wish to assign the sample to, red circle and arrow on right...
but first you are going to need to put your samples in a folder in My Documents like this one
Notice I call mine drops, makes it easy to find...once its open just double click on the sample you want,,,
If you were successful the sample name will show up differently in the field below the sample....
I hope that helps....good luck, sometimes you might need to do it more than once
Posted Thu 18 Oct 07 @ 7:38 pm
Thanks TearEmUp, for the pictures.
I shall try, if I have problems i'll post back.
Jimmy b
Posted Thu 18 Oct 07 @ 8:30 pm
