In one of extern drives (database) it says about 40000 total entries 39600 in Search DB, 400 present but hidden from search.
How can i get the 400 back to the search?
Posted Wed 17 Oct 07 @ 10:03 am
anyone any idea
Posted Wed 17 Oct 07 @ 4:07 pm
could it be those files are corrupt? maybe unknown file types? does it only do it with that H?
Posted Wed 17 Oct 07 @ 6:03 pm
I beleive the music on your data base is needing to be reanalyzed. Yes, at one time it may have been done but do to some kind of corruption. It got lost. Everytime I start my system I can go through my folders and find some that either lost their analyzed content or BPM or is not in the search DB any longer. I conclude it to when I sometimes load the software up. It sometimes gives me the video driver error or incorrect resolution. The thing is that I know what causes each error so I try not to do it for next load.
If I disconnect my video input, the software doesn't switch to default without letting me know the video X driver... second, I go from one computer to another with a different resolution. I may get an popup.
Posted Wed 17 Oct 07 @ 7:19 pm
just a thought these files may not be showing because they are duplicates...
Tayla
Tayla
Posted Wed 17 Oct 07 @ 7:24 pm
I just realized i had the same problem, this is how i fixed it.
settings -> browser tab -> changed "Search Database" to read "Add Automatically"
Turns out the files were there the system just didnt add them to be able to search for them. umpf!
Posted Wed 17 Oct 07 @ 9:02 pm
i think i done this if i started with the new version. I selected the mp3 in the browser with the right mouse and then remove from DB.
How can i get them back
Posted Thu 18 Oct 07 @ 6:12 am
Ok its one thing to analyse tracks its another to add them to the search database.
By setting it to " Add Automatically" its will do just that, the songs will already be analysed.
You can also press ctrl+a and -> right click -> search DB -> Add to sear DB
Posted Thu 18 Oct 07 @ 1:53 pm
