Hi I am a Virtual DJ user, and I having a problem parsing titles of Arabic songs. They are being parsed are rubbish characters, and I have tried to change the font settings of the program but to no avail. I think this may be a Unicode implementation problem, so please tell me how to resolve this problem as soon as possible, cause I have a few thousand songs in Arabic, and I cannot go through the
process of renaming each and every file! Your help is highly appreciated. I have tried every possible alternate setting for the language (Hebrew, Slavic, etc..) and the font (Arial, Times New Roman) and nothing seems to work!
I know that this can be solved, since I encountered the same problem with another similar program.
Posted Sun 31 Oct 04 @ 10:27 pm
I don't know for arabic, but for Greek, this is the solution:
Go to the skins directory, extract the xml file from the skin you use, (lets say from default.zip)
The fonts used are Tahoma.
Edit this file with notepad.
What i do for Greek:
Notepad-->edit menu-->replace (control+H)
....to replace all "Tahoma" fonts with "Arial Greek"
-Try something simillar for arabic.-
Then save the file and copy it to the zip again (replacing the
original)
Let me know if it works.
original)
Posted Mon 01 Nov 04 @ 12:49 am
hi there i try it all and nothing change ???
Posted Tue 02 Nov 04 @ 11:11 am
