HI,
I just plugged in my external hardrive after 2 weeks of not using it. On it I have like 10 major folders. 1 folder is called Early night. Inside that folder WAS another folder called Early night older.
Here's my question.... this never happened before
When I open Vitual DJ, I get a little yellow warning looking message that says
"VirtualDJ Virtualdj.exe - corrupt file
E:/o2early night run chkdsk utily.
THe SUB folder is gone along with all the songs in it.
Can anyone tell what might have happended, and can I get that folder back?- I looked to see if I just moved it but to no avail.
How will I ever get that Yellow message to go away?
Thanks,
B
Thanks,
B
Posted Thu 11 Oct 07 @ 5:17 am
was the folder created in virtual dj? Or was this a windows folder? If windows folder you do not see this in windows explorer? If this is the case sounds like your hard drive may be going or has went. There is software out there that can recover your data. If you need help PM me.
Posted Thu 11 Oct 07 @ 5:50 am
HI.
It was a windows folder. When you say going- is this usually a sign something larger will happen soon? More folders corrupt or total drive gone?
Is it possible it will stop at this 1 folder? I do not care too much about hte music there- I have a backup- more concered about my whole drive.
I am running windos chdk disc utility for the first time on the entire drive to "scan for and atempt recovery of bad sectors"- looks like will take many hours.
your thoughts?
thanks,
B
your thoughts?
thanks,
B
Posted Thu 11 Oct 07 @ 6:00 am
Woke up today- came down and the chsk finished-
My folder came back.
I hope I am ok to proceed with using the drive and VDJ in the club-
does anyone think I need to go out and buy a new drive or should I be fine now?
thanks,
B
thanks,
B
Posted Thu 11 Oct 07 @ 11:40 am
i would be worried about that drive ......back it up immediately ....even if the drive were ok , no harm done backing it up.....
i keep a back up on my home / back up system
Posted Thu 11 Oct 07 @ 11:59 am
HI,
I will back it up and would do it anyway- but when you say you are worried- why do you say that? becuiae of what happened with 1 file as described above?
B
B
Posted Fri 12 Oct 07 @ 5:06 am
I would agree. I've had this kind of thing happen to me. Be thankful that your drive gave your fair warning. When Windows has a hard time writing data to the drive, you know it's about to go. Even a format can't help it at that point. Backup immediately.
Posted Fri 12 Oct 07 @ 6:49 am
