Topic: Needing Help Please
Hi I'm New To The Site,
I Have Just Got The VDJ 5 And Every Time I Go To Launch It Its Come Up With A Gray Box Sayin...
Basic Interface.
Power Aufio Interface.
Full Audio And Video Interface.
Internal Mixer Interface.
I Have Tried Clciking On Every One To Load It Up And Every Time I Do It Come's Up With An Error Box Saying:
Invalid Skin File (Error Line %i in the xml)
And Will Not Let Me Launch VDJ 5
I Previously Downloaded The Free Trial Version And It Wouldn't Let Me Select The Basic Interface So I Choose The Internal Mixer Interface And That Worked..
So I Decided To Get The Programe And Now It Wont Work....???
Can Some One Please Please Help Me... It Would Be Much Appreciated..
Thank You Steve.
Posted Sun 07 Oct 07 @ 8:14 pm
Thank You Steve.
Did you buy VDJ?
If so please enter serial here:
https://virtualdj.com/fusers/modifuser.html
Will let you have access to all features and downloads etc
for the skin thing, delete VirtualDJ.zip in skin folder, and reinstall
Strange, haven't heard this one before. Anyone?
No A Friend Recomended Usen Torrents To Download It So I Tried And Worked But This Happend?? I Think I Will Just Buy It If Know One Know's The Problem?
A "c" version like that prone to have problem.. As u say u use legal trial version i think it may be something or u have the older "c" version in ur system. Fully uninstalled it n buying the genuine product would cure it:)
Yeah, b/c piracy seems so pervasive nowadays, "c" versions have a way of throwing VDJ into a protected mode that generally can't be undone. Just do what Spinna suggests and u should be fine ;)
That is an illegal pirated warez version, and since the hackers change the code, dont expect it to work good..
And might even contain virus, spyware and more...
thank's alot people... appreciate your help.. a may just buy the full version instead but its actualy working fine now to be honest a bit wierd like :S:S
ohh well thank's alot...
You buy the full version, all the updates and plug-ins, and effects, all those goodies are FREE. Even if it's an upgrade from 4.0 to 5.0 to 6.0 ALL FREE for life (so far) If you like the software, it is worth purchasing. Plus FREE tech support.
At this moment, since you admitted to using the pirated version, your not going to get much help with it ;-) so your stuck.
Hope to see you as pro user soon!
