Hi,
would it be possible to rip vinyl in wave format as i need to edit my files before using them.
If this isn't possible,whould it be possible to add this in the next update ?
Posted Sat 06 Oct 07 @ 3:25 am
anybody breathing out there ???
Posted Sat 06 Oct 07 @ 6:06 pm
i guess everybody's sleeping !!!
Posted Sun 14 Oct 07 @ 12:48 am
You will need to use another tool. I use Cool Edit for Capture/Edit.
Thanks,
Thanks,
Posted Sun 14 Oct 07 @ 3:12 am
i use other tools but i want to know if i can do it with rip vinyl ? or can the feature be added in the next update ?
Posted Sun 14 Oct 07 @ 5:25 am
Rip Vinyl records MP3 format which is an editable format by most music editing products. Why the need for WAV format ?
And if you are using a licensed product please register -- https://virtualdj.com/fusers/modifuser.html
Posted Sun 14 Oct 07 @ 5:42 am
i need wave because i can edit the file without loosing the quality and them put the final file in mp3
Don't you know that you loose quality when you try to edit mp3's(ie..remove silence from the beginning and end, remove pop and clicks.
Most apps where made to edit wave files without loss of quality and not mp3 wich is a loosy format.
Posted Mon 15 Oct 07 @ 3:13 am
