Does Virtual DJ work with this product?
Posted Thu 04 Oct 07 @ 5:16 pm
it can be midi mapped , using
options > remotes
and the midi option
options > remotes
and the midi option
Posted Thu 04 Oct 07 @ 5:55 pm
Any idea when a mapper and skin will be available? (mapping isn't my strongpoint!)
Posted Thu 04 Oct 07 @ 6:20 pm
I'll create a custom mapper plugin for the Denon HC4500 once I can get hold of one (Not available in the UK yet) and native support is added to VDJ.
Posted Thu 04 Oct 07 @ 8:00 pm
I'll be waiting patiently! I want to buy one, but don't want to do it until I'm able to use it! (Maybe the folks at Denon will send you one so that you can get the rest of us hooked up! hint..hint...)
Posted Fri 05 Oct 07 @ 12:27 am
