I see you did the mapper for the xponent controller can you please supply us with some feedback on how you like it ,is there anywhere to plug in a mic & can you list the dimentions of the unit?
Again thanks & keep up the good work..................................
Posted Thu 04 Oct 07 @ 3:51 am
the xponent is a killer controler
the jog wheels are touch sensitive and the level of sensitvity can be adjusted , it can be so sensitve it dectects the hairs on your skin touching it
scratching quality is amazing ,
for close up shot click here
it has buttons for pretty much any coneviable task
it has a headphone jack
and two master outs one for a both monitor system and one for an amp
the sound quality is extremely high ,
Note
Torq DJ software its self is a bit like MY first DJ its realy unstable :(( dont install it
4-output USB audio interface:
4 RCA outputs for independent control of the house system and booth monitors
¼” TRS headphone output with cue and volume controls
16-bit/48kHz max sample rate
ASIO and Core Audio compatible
advanced MIDI control surface:
mixer controls:
2 vertical volume controls
2 3-band EQ control knobs with kill buttons
2 gain-control knobs with mute buttons
horizontal crossfader control with transform buttons
2 LED volume meters
player controls:
2 touch-sensitive scratch wheels
2 100mm pitch adjust controls
built-in touchpad/assignable X/Y control surface for mouse or effect control
8 assignable knobs for effect control
64 assignable backlit buttons, including Play, Cue, Seek, Loop, Key and Sync controls
2 LED progress meters
in software which has native support for it it can aslo flash all the buttons to the beat for visual beat counting :))
Note
mixer controls:
2 LED volume meters
player controls:
Posted Thu 04 Oct 07 @ 11:40 am
wohooo this is really close ;)
Does this one have a soundcard build in. How about mic and headphones?
Happy mixing whatever you software is called
Tanzi
Tanzi
Posted Thu 04 Oct 07 @ 11:43 am
it doesnt have a mic input unfortunately but it does have an xtremly highquality jack headphone input
Posted Thu 04 Oct 07 @ 12:08 pm
Hi Sky,
so you will have to use an additional soundcard, is this right?
Tanzi
Tanzi
Posted Thu 04 Oct 07 @ 12:44 pm
no its got a built in Muadio Card
with two stero outs
and a headphone jack
with two stero outs
Posted Thu 04 Oct 07 @ 12:45 pm
Man you are really fast .... ;)
How about the buttons. Can jou asign them completely free with VDJ?
Tanzi
Tanzi
Posted Thu 04 Oct 07 @ 12:47 pm
yes they all are seprate midi notes , so you just follow the standard mapping producedure
Posted Thu 04 Oct 07 @ 12:49 pm
How about the midi sendback for the lights?
THX Tanzi
THX Tanzi
Posted Thu 04 Oct 07 @ 1:35 pm
that would need a native mapper , which may be added soon :)
Posted Thu 04 Oct 07 @ 1:55 pm
"may" and "soon" - thats all we read since months on the Xponent topic,
why can't someone (teamer) be a little more specific,
PLEASE, we need some info, PLEASE
Posted Thu 04 Oct 07 @ 2:04 pm
Thx for your reply Sky, i've once spent a lot of money for the combination of VDJ an the BCD because of that "may be added soon". I think i will wait until someone says "Wohooo IT WORKS" ;)
Tanzi
Tanzi
Posted Thu 04 Oct 07 @ 2:14 pm
If I wanted to hook up a mic so basicaly all I need is vdj,the controller & 2 selfpowered speakers how would you suggest to do it? And can you list the dimentions of it Thanks for all your help..............
Posted Thu 04 Oct 07 @ 2:36 pm
As sky said.
The Xponent has no Mic-in. So if your active speakers have no mic in you would need an additional small mixer for your mic.
Tanzi
Tanzi
Posted Thu 04 Oct 07 @ 3:39 pm
I tought that is what I would need to do.
What are the dimentions?
Posted Thu 04 Oct 07 @ 5:15 pm
i will measure when i get home :)
it is quite large but this is good for controling
if your limited for space get the mini VCI controler
Posted Thu 04 Oct 07 @ 5:53 pm
hey skyfxl,
can I download you mapping somewhere?
Posted Thu 04 Oct 07 @ 6:13 pm
Posted Thu 04 Oct 07 @ 10:50 pm
M-Audios homepage says about the dimensions
ca. 45,8 x 30,4 x 5,7 cm (height of Wheels)
Happy mixing whatever your software is called
Tanzi
Tanzi
Posted Thu 04 Oct 07 @ 10:57 pm
xponent now natively supported in V5 r4
Posted Sun 07 Oct 07 @ 9:34 pm
