Hello,
i have two monitors and won`t to open vdj two times, that i have four player, if i close one and open him again all the drives (database) are gone.
Any idea
Any idea
Posted Mon 01 Oct 07 @ 7:20 am
Are you looking to have 4 decks or two VDJs ?
Posted Mon 01 Oct 07 @ 8:17 pm
have you enabled multi instance mode in options?
what version do you use?
Posted Mon 01 Oct 07 @ 8:20 pm
yes, i enabled multi instance skin, vers. 5.2
the second instance opens fine, but after i close the second instance and reopen all
is gone.
in the old version there was an second file _2
cannot find it in the new version
is gone.
Posted Tue 02 Oct 07 @ 6:49 am
Hello,
the second virtualdj database where you can fix there are no drives
Posted Wed 03 Oct 07 @ 8:41 am
Its a limitation we know. The 5.0 version doesnt allow multi-instance yet.
Will be fixed :)
Posted Wed 03 Oct 07 @ 9:45 am
Thanks for the quick answer
Posted Wed 03 Oct 07 @ 11:29 am
with the release of VDJ 5 rev 4 has this been fixed??
Posted Tue 09 Oct 07 @ 1:59 pm
i don`t think so
Posted Tue 09 Oct 07 @ 2:24 pm
