Topic: please help!!!!!
I own Virtual Dj Mp3 Control ( with the hercules consol).
I bought it at the start of the year and everything worked fine. Last night I had to format my computer and when I came to re install Virtual Dj I realised Ive lost the serial code!!!! I have absolutely everything else exept the serial!
What can I do??
Please Please Please help.......
Posted Sun 30 Sep 07 @ 4:39 pm
cstollPRO InfinityMember since 2004
Since you registered your software, you should be able to go here - http://www.virtualdj.com/update.html - enter your forum login password. You should then be able to see your serial # on the resulting page.
Posted Sun 30 Sep 07 @ 5:12 pm
