Hello mates
Just wondering if anyone out there would be able to lend a hand to a new virtual dj man. My issue is that the software is not responding to the proper speed of the jog wheels. I spin the wheels or scratch, but the virtual dj program does not move on time as it should.
Help
Help
Posted Tue 25 Sep 07 @ 9:06 pm
what is your machine spec , what version do you use?
Posted Tue 25 Sep 07 @ 9:11 pm
Dj Console MK2? Or am I missing other version info?
Posted Tue 25 Sep 07 @ 9:18 pm
The dj console is an entry level controller, and not meant for pro scratch.
It might just be the how the controller is, its not good for super fast scratches, as the jogwheels are not touch sensitive in the real sence of the word
Posted Tue 25 Sep 07 @ 9:25 pm
which version of vdj?
before writing of the console for stratching , check this link here
https://virtualdj.com/forums/68291/Hardware_Technical_Support/Some_general_info_about_Hercules_DJ_Console_MK2.html
detailing how to improve its responsiveness and sound quality
Posted Tue 25 Sep 07 @ 9:31 pm
Hi Joey, Got 2 things to check,
Step1 - Open the DJ Console MK2 Mixer, in your Start up Menu, If not there go to your All program List, Once open go to the Advanced and see if both are set to Enable (default setting) in the jog wheel settings.
Step2 - Open up VDJ and go to the config settings, in the top right corner, click on that. Then go to the Remote Control tab and click on that.
You should see the Hercules DJC. Tick Use both Jog Wheels to scratch. Then OK.
Hopefully you should now have full controls off your jog wheels, If not it might be a driver issue, check to see if you have the 2007 drivers.
I hope this works for you.
Jimmy B
Posted Tue 25 Sep 07 @ 9:41 pm
