No1. How do i view the songs i have already played in the order that i have played them, like a instant playlist?
2. Some songs coem up with cue on and they play from anypart in the song wher the cue is set, easy to click back to the start but wanted to know how to take it off?
and yes iam aware of how easy these questions are to solve but hell i icant do it, thanks plenty!!
Posted Thu 13 Sep 07 @ 5:20 am
Create a Filter Folder and call it whatever you wish. (I call mine recently played) Use this code for the filter:
days since lastplay<1
You will need to enable the "Last Play" column in the browser and click on it to sort by the last played time.
To remove a cue point, right click on the cue marker in the waveform window and select "delete". (Sometimes getting the right cue mark can be tricky if you have more than one close to each other.)
Posted Thu 13 Sep 07 @ 5:36 am
goto config > options > auto cue > disabled
FYI, as i remember, with auto cue enabled vdj only jumps to the 1st cue that is set
in other words, if you don't have a 1st cue assigned, but a 2nd one
the song will play from the beginning
cheers,
matt
cheers,
matt
Posted Thu 13 Sep 07 @ 6:05 am
You can also just look under the history tab on the left and songs will be listed in the order played.
Posted Thu 13 Sep 07 @ 9:11 pm
Ahh, i have no history tab anywhere on the left. only lock, virtual folder, and set as favorite folder.
Posted Fri 14 Sep 07 @ 4:57 am
Are we talking version 5 ? Or, version 4.x ?
Posted Fri 14 Sep 07 @ 4:59 am
Im talking about version 4. Sounds like version 5 allows this? I will have to update then.
Posted Fri 14 Sep 07 @ 9:51 am
Yes, V5 has the 'instant playlist'. v4 has a history.txt you can look at but not during a session to see what you have played.
Posted Fri 14 Sep 07 @ 1:27 pm
ok that all sounds good.
I will have to download version 5, cheers for that mate.
Posted Sat 15 Sep 07 @ 4:10 am
"quote=djderrick"Create a Filter Folder and call it whatever you wish. (I call mine recently played) Use this code for the filter:
You will need to enable the "Last Play" column in the browser and click on it to sort by the last played time."unquote"
In effect what will this actually accomplish?
I created a filter folder and did exactly as was described, i get the tracks that i have lasted played come up at the bottom of the browser, but i also have about 31 to be precise tracks that are above it.
I think this may have something to do with enabling the "last play" colum but i am unsure how to do this?
Posted Fri 05 Oct 07 @ 2:36 pm
Anyone can answer this one. I know version 5 has history but it is at the bottom of all the other history pages in the list and i dont want to waste time scrolling.... I know im picky :-)
Even if there is a way of making the ""most"" recent history at the top of the list or deleting the history so the most recent is at the top?
P.s i tried deleting the history by selecting, scrolling and deleting in the history folder but it still seems to show up in virtual dj
Posted Mon 08 Oct 07 @ 12:54 pm
