Topic: admin i need help....regarding my mk2 bundle
ok i bought my mk2 bundle which includes the vdj ver2.0 and i dont know if theres something wrong.......first is thers no sound going out my laptop what should i do? or i need speakers? cant i use the laptops speakers? second is i cant locate my mk2 system tray icon ....which i think answers my problem cause i cant setup my outputs ..hope you can help ..thanks in advance
nixp
few more questions:
can i mix videos?? if i can how?
Posted Sun 09 Sep 07 @ 8:54 am
hello there ,
you need some speakers to use with your mk2 ,
if you are djing at home , any computer speakers will do just replace the mini jack to phono cable
with a dual phono cable , or if you are doing events an amplifier and larger speakers would be a good investment,
this diagram shows how you can connect it each line is a dual phono cable , you dont have to use turntables or the mixer if you dont want to (external mixer only in pro )
you should have version 3.4 console edition , grab the latest
at https://virtualdj.com/update.html
you can mix videos if you have a good video card , in a video window
if you would like to do full screen video mixing you need pro ,
what video card do you have?
to learn more about what is included in console Edition ,
look at the comparison
should you want the features of pro , you can upgrade at a
discountas you own the mk2
thanks for the help.....one last thing can u give me softwares that can work with the mk2? and where i can download it..
if u using the v3.4 that the latest n should werk with the console, however u might try the pro version trial first, n then if u like it n fits r needs, u could upgrade it at a discount:)
https://virtualdj.com/download.html
go here and type your password
i updated my vdj....but wondering if wat else (software) besides vdj would best work for my mk2? thanks ad if where can i download it
and advice for the timecode cd ..cause i didnt quite get it ...
timecoded cds are special cds with a binary code on it , which allows virtual dj to be controled by cd players
download the timecoded cd
https://virtualdj.com/products/timecode/cd.html
burn two audio cds of it ,
then follow
https://virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
(please note console edition is limited to 5 minutes per song timecoded use to give you a taste for it)
you can upgrade at a discount
as you own the mk2 for unlimited usage.
Other software which works with the mk2 are :
Traktor (no video or tcv support with mk2) , and deckadance (no video)
But VDJ is definitely the best option of them all!!! I have tried many but none is as good as VDJ. I really advise you to get the full version of the program at the discount price. You will not regret it.
oh ok thanks for the infos......btw where could i download traktor? and would traktor 3 work??
p.s. my video window has a green thick line in the middle when i play videos? whats wrong?
we dont do traktor support here...
how do i check my video card?
mobile intel (R) 915gm/gms, 910gml express chipset family.... is that it?
that chipset is for office pcs not multimedia
you need at least 256 mb dedicated vram
thank you skyfxl ....learned a lot.....
nix
your welcome sorry to be the bringer of bad news
no problem..........
hey why cnt i see my control panel settings (system tray icon)?? i mean it was in my manual 6.4 page 10...but i cnt find it im my vdj
look on control pannel
or in the hercules program folder
c:/programfiles/hercules
