I am aware that there have been a several problems with the MK2 discussed in here but I've search and found nothing about my problem.
There's no sound coming out of my Hercules either from the headphone monitor nor the output in the back. The controls work like the fader and the volume, like I can move them up and down and left to right but NO Sound?
Here's what I've done so far:
1. I've downloaded the latest version of the Hercules driver from their website.
2. I've adjusted the volume on the Control Panel for Hercules.
Btw, the primary sound card on my laptop works.
TIA
Posted Sun 09 Sep 07 @ 3:42 am
for pro vdj
the following settings must be used
Sound options :
inputs : none
outputs : headphones
card : mk2
channels 1/2 main 3/4 headphones
Sound options :
inputs : none
card : mk2
Posted Sun 09 Sep 07 @ 1:37 pm
I did that and it's still not working. I even did
Sound Options:
Inputs: None
Outputs: external mixer
card : mk2
channels: 1/2 left and 2/4 headphones
The strange thing is I can't even hear anything from the mk2 headphone monitor but like what I said all the controls on the mk2 is working. Just no sound.
Posted Tue 11 Sep 07 @ 8:18 am
i suggest you contact hercules who will help you to try to reset the card , or return it to the shop of purchase
as it sounds like a faulty unit.
Posted Tue 11 Sep 07 @ 5:07 pm
