Hi, im haing slight problems with sound quality of my MK2 . With some songs im hearing slight clicks and distortions ,like some sounds just bottom out right at the end and make a click .settings are spot on in virtual dj , i think this is a hardware problem .I cannot set the sample size above 16 bit of the sample rate above 44100 Hz with out hearing a mega distortion .Can anyone help ,or is this just the case of the Hercules being a not so good sound output ? Is it worth upgrading to a professional sound card ?
Cheers
Adam
Cheers
Adam
Posted Thu 06 Sep 07 @ 1:34 pm
what are your computer specs?
Posted Fri 07 Sep 07 @ 6:50 pm
