Doesn't work in 2.05, says 'error in line 0 of xml'
Anyone else get the same problem? Anything we can do about it? Would really like to try this skin.
Cheers,
Bill.
Cheers,
Bill.
Posted Fri 22 Oct 04 @ 12:57 pm
I have the same problem!
Posted Fri 29 Oct 04 @ 3:00 am
this is what i did....
open the xml in explorer not in notepad.
you see that it won't open. a message come in the browser with a textline witch is wrong.
open the xml in notepad and delete the line
it's the ------------------cbg button-------------
and the resetvallue of the headphonevolume.
works for me.
works for me.
Posted Fri 29 Oct 04 @ 5:39 am
Good job djjb. It works for me too.
Have you used the fixed Traktor skin extensively (in a real mix session) to knwo that there is not hidden additional bugs.
Posted Sat 30 Oct 04 @ 12:29 am
no bladerunner.
i sow your problem and worked on it.
when i bought the console a year ago, i used the trak.skin for a long time.
but the last half year i use my own skins.
Posted Sat 30 Oct 04 @ 3:14 am
