Sometimes i drag & drop an un-analyzed file into the player and it won't be processed (bpm scanned auto) from VDJ. However if i go manually to that folder and i press analyze it does it without any problem. Maybe a bug?
Posted Wed 05 Sep 07 @ 9:52 am
First of all which version are you using?
Posted Wed 05 Sep 07 @ 7:37 pm
When you drag & drop, it uses the bpm engine you have selected in the options portion of configure. When you choose manual, you have a choice between two engines. Are you using the same engine in both cases?
Posted Wed 05 Sep 07 @ 7:41 pm
