Hey I am not entirely sure how this works. I downloaded asio4all and I ran that and virtual dj says that I dont have enough channels for 2 turntables but I can use one. I have a built in sound card not a usb, I am assuming it is comparable to the behringer usb 202 model channel wise. I am just trying to figure out how I would set this up? and how does using one turn table work? I am not really sure where my monitor and headphones would come out of either. Thanks alot
Posted Wed 05 Sep 07 @ 3:21 am
for setting up tccd/tcv refer to my guide
found http://www.virtualdj.com/forums/76267/Hardware_Technical_Support/TCV_TCCD_Setup_Manual.html
for the rest, i dont htink you will be able to use two timecodes on the onboard sound card.
select single time code and follow my guide to configure it.
Posted Wed 05 Sep 07 @ 8:53 pm
