The L.E.D.-displays or V.U.-meters of Virtual DJ are always showing the same level and have nothing to do with the incoming- or outgoing level.
So adjusting the gain and using PFL don't actually show the incoming level. And the L.E.D.-display or V.U.-meters don't show the outging level of the faders. The exact playback- or recording-level now is not very clear to see.
Can Virual DJ be set so that the L.E.D.-displays or V.U.-meters are showing the incoming and outgoing-level? And that the L.E.D-display or V.U.-meters reacts by adjusting the level just like a real mixer?
Posted Tue 04 Sep 07 @ 12:06 am
might be possible, by skin code. If not, its a good idea for future skin feature
Posted Tue 04 Sep 07 @ 1:21 am
My earlier question about the L.E.D.-displays or V.U.-meters is not described correct. This should be the question:
The L.E.D.-displays or V.U.-meters of Virtual DJ do response by using the Gain to adjust the incoming-level. But they don't response on the
outgoing-level by the faders.
Is it possible to set the L.E.D.-displays or V.U.-meters so that they do show the outgoing level and response on the faders ? By choice then the
incoming or outgoing level could be selected or displayed.
(With a real mixer the PFL-fuction offer this possibility.)
Posted Tue 04 Sep 07 @ 2:18 am
