Posted Mon 03 Sep 07 @ 9:35 am
A BEAUTIFUL THING!
I CAN FINALLY use my mbp (via bootcamp 4.2), vdj 5.0, vista & YES my serato box! F***** WOW!!!!
excuse the language...but finally!
Anyone having problems with 5.0 & using XP I suggest take the leap & do Vista....its basically like xp if u turn of all the crap pop up securitys (although i do see how it will help the non average computer user)
also I'm running vista standard...not even shell or any tweaks....THIS IS A STRAIGHT INSTALL........of course adjust config settings....but thats it....no other tweaking!
Quite Amazing.
[Moderated] cstoll
Quite Amazing.
[Moderated] cstoll
Posted Mon 03 Sep 07 @ 9:43 am
btw i use this computer for my work....just about all the media software can think of. Also yes my wifi was enabled & connected when I was mixing for over 2 hours.
Posted Mon 03 Sep 07 @ 9:46 am
Good for you, but don't use F word in public forums ;)
Posted Mon 03 Sep 07 @ 10:08 am
Funk, Hopefully in the near future we won't have to even run Windows on our Mac's....
I may install Vista myself, now that I see you and Quest are using it.
Posted Mon 03 Sep 07 @ 8:39 pm
BTW, Vista + VDJ ROCKS on a normal PC too...
I know there are vista issues in other regards, but as far as DJing with VDJ I love it..
Posted Mon 03 Sep 07 @ 9:09 pm
Yupper. =D
Do it C5.
Like I posted on several threads, I spun 6 hours last Friday night using TCV's, 5.0 (didn't want to install rev2 on the day of a gig without testing), and vista.
Flawless. =)
- VT ConQuest
(Visual Turntablist)
Posted Tue 04 Sep 07 @ 5:48 pm
Tell Microsoft I want my bloody ram back :P
No but on a serious note.
Stupid Vista. I had the whole kernal crash middle of gig. Thats probably just back luck, but beware may happen to you :P
Besides the drivers for most sound cards are not really vista compatible, even the maya 44 driver which is supposed to be vista compatible technically isnt.
Posted Wed 05 Sep 07 @ 8:04 pm
