So I'm playing audio from another source but want the sonique stuff to move or the video efx to move to the beat.. I figured I could use bypass and feed audio thru my soundcard but nothing happen. I hope this makes since. If this is currently not possible, then it would be nice in updates. I guess the easiest would be allowing audio trigger from the input of the bypass .
Posted Sat 01 Sep 07 @ 10:33 am
Bump !
I guess the is addressing a question of if you were playing a piece of vinyl using the bypass would the audio sensitive efx function in virtual dj.
Posted Sat 01 Sep 07 @ 6:43 pm
try this:
Locate your soundcard at VDJ browser (under Desktop), and try drag and drop the soundcard that has the audio source input to a deck in VDJ.
Not sure if it works, but slight chance it might ;)
Posted Sat 01 Sep 07 @ 6:46 pm
I tried the pasting the sound card but it didn't work. Is there anything else i can try?
Posted Mon 10 Sep 07 @ 4:37 am
did you try dragging the sound card on the deck?
Posted Mon 10 Sep 07 @ 5:53 am
When I do that it crashes vdj 5.02
Posted Sat 29 Sep 07 @ 7:32 pm
