click on config
in settings find space and delete
click on add and press space bar / mixer/ autofade / on default / then go back to settings
click on add and press on space bar /deck controls / play / on default / tick auto / then go back to settings
click on add and press space bar / playlist / load from playlist / on active / then go back to settings
Job done, when pop appears answer yes to all
You may have to hit space bar twice to start the automix playlist
Hope this makes sense
Posted Sat 01 Sep 07 @ 12:25 am
Better explanation here - AUTOMIX SHORTCUT
Posted Sat 01 Sep 07 @ 8:26 am
