Well I've been messing around with VDJ5 on my home computer, and it's been running for over 16 hours now with automix on without a hiccup. Hopefully it'll do so well on the gig machine.
Posted Fri 31 Aug 07 @ 7:35 pm
Good to hear ;) and ditto... its working extremely well for me too
Posted Fri 31 Aug 07 @ 7:40 pm
Blah.
You call that testing.
Auto-mixing tests one function of the program.
Actually USE it and mix and do multiple functions at once, load songs quickly etc etc
to actually TEST it.
Putting it on automix umm ? to test if its gonna crash after certain amount of time :/ like a demo mode or something :/
Posted Wed 05 Sep 07 @ 8:44 pm
I have used my v5r2 on radio several times now and on the road for several shows, both auto mix dinner music and regular mixing, including multiple effects and loading and unloading fast, and radio style segways. No complaints from me... ;-)
Posted Wed 05 Sep 07 @ 8:50 pm
lol i've been beating the hell outta it "VDJ 5r2"
(that did not sound good lmao)
no crashguard's, no VDJ related issues.
the change from 5 to 5r2 corrected a small but big issue i had ;)
Posted Wed 05 Sep 07 @ 9:15 pm
I agree with testing method used... Make sure you test all the variation of the search engine. All your plug-ins, loading and changing song speed. Everything you would do at gig plus. Unless you use automix for most of you gig then you have properly tested. Heck, I use automix in the morning wile I get ready for work. I throw about 8 songs on the list some with video and I do everything I would do if it was a standard CD player. skip, fast foward, backwards, jump songs. I know the automix works.
I worry about the multi function for a show.
My only concern right now is playing a visual plug-in during audio play. Nothing locks or freezes but the smooth transition from one function to another. I'm looking into keystrokes for many of the affect and transitions.
Question: how do you keystroke hotbuttons. I can't figure it out. I know it's been answered but I can't remember which thread it was in.
Posted Wed 05 Sep 07 @ 9:28 pm
Look in your CUE v5 manual in the My Documents -> Numark CUE folder. You should find your answer in the Keyboard Shortcuts section.
Posted Wed 05 Sep 07 @ 9:31 pm
