tcv will work when i start the program. then, out of nowhere i cant control the deck with the tcv. the music keeps on play but the music will not repond the the tcv. when i notice this i tried to go to the vinyl auto config but it didn't pick it up. the only way is to restart the program.
Vista
Version 5
1.5 ram
serato sound card box
external hard drive
tcv gen3
Vista
Version 5
1.5 ram
external hard drive
tcv gen3
Posted Fri 31 Aug 07 @ 4:51 pm
I've got the same problem too. The more I play, the less I have tcv signal, then impossible to play...
Recalibration also doesn't work all the times.
I have a Maya 44 USB. It worked and works fine with the 4.3 version.
Posted Fri 31 Aug 07 @ 6:14 pm
Try setting the pitch sensitivity higher. Its EXTREMELY low in 5.x (100ms), where as 4.3 had a higher setting (2000ms)
See that works better for you guys.
Also remember to set latency to AUTO in VDJ performance tab with the Maya and other PRO soundcards
Posted Fri 31 Aug 07 @ 6:18 pm
Try refer to my guide see if it helps..
https://virtualdj.com/forums/76267/Hardware_Technical_Support/TCV_TCCD_Setup_Manual.html
Posted Wed 05 Sep 07 @ 8:48 pm
