I recently did "format" in my hard disc due to a virus. Unfortunately, I also lost my serial number for Virtual DJ Pro and I can't reinstall it. Could you please tell me this damn number, or even tell me where I can find it? PLEASE HELP ME!!!!!!
Posted Fri 31 Aug 07 @ 3:22 pm
go to download centre and install your password and your serial number will be on screen...
Tayla
Tayla
Posted Fri 31 Aug 07 @ 4:34 pm
Never has registering your software been so helpful
Posted Fri 31 Aug 07 @ 5:19 pm
Dear Tayla, the problem is that I forgot to register my new serial! Is there any other way that I can find it?
Posted Mon 03 Sep 07 @ 6:24 pm
Did you save the email that atomix sent you when you purchased the product?
If you did then you still have the serial - it's in the email.
otherwise you are stuck contacting support
Posted Mon 03 Sep 07 @ 6:28 pm
Unfortunately I didn't, any other way?
Posted Mon 03 Sep 07 @ 6:43 pm
Not That I know of.
Contact support
Contact support
Posted Mon 03 Sep 07 @ 6:50 pm
contactsupport
Posted Mon 03 Sep 07 @ 7:00 pm
I think you're screwed
Posted Tue 04 Sep 07 @ 4:22 pm
This can be resolved through eTicket - do as skyfxl recommended.
Posted Tue 04 Sep 07 @ 5:12 pm
