Hi guys
One problem that has come to light is as follows
All my media files are fresh to virtual DJ5, no old database files
I started to read in new VOB video files and add Genres / BPM etc.
The way the were titled on the hard drive was as follows
01 Artist - Title
02 Artist - Title
etc...
After adding all the Genres & Bpms etc. I then reliased I really wanted them stored on my hard drives as ....
Artist - Title
Artist - Title
etc...
So I renamed them by removing the track numbers.
By doing this I ended up losing all my Genres & BPM and track data in Vertual DJ for each file.
is this because the new database hooks on to each filename for the tagging data/info
or am I doing something wrong, also is the any utilities for editing the new database files in Virtual DJ
Thanks
John
01 Artist - Title
02 Artist - Title
etc...
Artist - Title
Artist - Title
etc...
Thanks
John
Posted Tue 28 Aug 07 @ 1:06 am
No, you are not doing anything wrong. Whenever you change the way a file reads VDJ thinks its a different database.
Posted Tue 28 Aug 07 @ 1:20 am
Sorry, but Yes - you should not have renamed the files. VirtualDJ uses the absolute (exact) file name to reference the files.
So by re-naming them VirtualDJ believes they are now new files.
Recommendation (if you have not cleared your database) rename them all back. And use the Artist and Title fields from the file info. Go make sure all the files have an Artist and Title in the respective fields. Set the Artist/Title option in the Config->Browser tab to 'Only from Tag'
Posted Tue 28 Aug 07 @ 2:50 am
