Hello there,
I am using Vdj5 and it is not saving the effects.Whenever I change the slider for an effect or change the way it sounds eg tk filter or ghost effect on video,then close vdj it does not save the settings.When I open vdj I have to set them all over again.I normally use tk filter to reduce base on one channel when changing songs but in this version it resets itself to the original (factory) settings.Is there a way to stop this from happening.
The other thing is that when effects such as 32,16 band equalizer,TK flanger are on and you try to backspin manually on the deck vdj crashes.This has been happening to all versions from V4.I dont use decks but use mouse and keyboard but when I try to scratch while the mentioned effects are on the program hangs and am sure that the problem is not my computer.Any solutions?
Posted Mon 27 Aug 07 @ 8:30 pm
Hello there,
Posted Tue 28 Aug 07 @ 1:35 pm
