Dear all,
I have a creamware scope card (15DSP) installed in my machine for creating music, for a song which i am creating at the moment, i need a loose scratch running trough my creamware card. I would like to know if anybody was able to coop with this setup in combination of VDJ and Creamware Scope card. I was very impressed by the software in combination with EKS10, but i need to know if it is a realiable system in live situations. Also what is the delivery time of the controller and the software?
thanks in advance.
beste regards
thanks in advance.
beste regards
Posted Mon 18 Oct 04 @ 5:39 pm
I don't know about the creamware.
About the reliability in live, well, that's what we do.
And for the delay, it depends where you live.
The xp10 can take from 2 days to 2 weeks to be delivered.
The software has to be purchased separately (it doesn't come with the xp10), and you will have it instantly by download.
Posted Fri 22 Oct 04 @ 1:02 pm
I live in the USA, it took about 1 week (7 days) to get my XP-10.
I hope this helps.
As for the software, with a credit card purchase, it should take just a matter of minutes before you receive the download instructions and serial number by e-mail.
I hope this helps.
Posted Fri 22 Oct 04 @ 3:03 pm
How does the controller work in combination with the VDJ software, if I want to run a number, is the number loaded into the controller, or how does it work? sorry for so much questions but i am very interrested in buying a setup and do wan't to know if i do the right thing.
Posted Mon 25 Oct 04 @ 12:03 pm
