Forum: Old versions
Topic: Toggling Keylock causes audio to glitch?
Hey.
If you play a song at 0% pitch and rapidly toggle the Keylock button, do you hear the audio glitching? Here it glitches even with just one press but it can be very hard to notice* depending on the content played so toggle it on/off rapidly to verify if there's an issue with this.
No combination of settings in the Performances tab fixed this. I also noticed that Scratch: Simple/Enhanced algorithm seems to have a huge effect on overall audio quality (Simple setting = entirely useless, should be removed). The setting says it affects only Scratching so this is a bug.
This is with VDJ5 and with or without asio.
* Easiest to notice with lots of thick pads playing and little vocal laid on top.
Posted Sun 26 Aug 07 @ 10:36 pm
