Forum: Old versions
Topic: max load
what is the best configuration for the "max load"-option that VDJ runs stable in use with the DJ console??
VDJ crashes after about 5 hours working, mostly while loading a new song (at drag&drop).
thank you
greets
Andy
Posted Mon 18 Oct 04 @ 6:57 am
best option is FULL ("always") - if your PC have enough ram and power ...
Best setting is a balance between your ram and the songs
you load.
You have to avoid the use of the swap file, this can happen
if you set it to always (Dj in Norway).
And also avoid to load big files that not fit in ram.
(see the bugs forum for this - "memory leak2...")
So while you run the program open the task manager
alt+control+del and take a look to the used memory.
Lets say you will see 246525k/633204
246525k is the used ram (Windows+drivers+programs+extracted to wav audio files..)
633204 is the total physical memory+swap
If your physical ram is 256 Mb, you are ok but near to the
limits... dont count the swap-file ...
According to my tests 256 is ok for 5min files
512 for 10+ min files
etc.
