Forum: Old versions
Topic: DJ Console stops working after firmware upgrade
I upgraded the DJ console to firmware revision 34 and received an error message back. Since then my computer does not recognise the DJ console anymore and when I plug it in one of the USB ports, the computer reports an unknown device. When connecting to a different computer, I get the same result. Has anyone else had this problem and how did you get this resolved?
Regards
Ben Meijering
Posted Sun 17 Oct 04 @ 7:37 am
you have to reinstall..
succes
Thanks for your suggestion djjb. I re-installed a couple of times, even on a different computer, still the DJ console is reported as an unknow device in the list of USB controllers
Regards
Ben
Did you install the new driver as well as the new firmware?
After I tried to install the new firmware (which returned an error message), I installed new drivers, etc. It looks like the attempt to upgrade the firmware damaged the Console and now the Console is not able to identify itself anymore.
Regards
Ben
The new driver requires the newest firmware, so try uninstalling this driver, and installing the previous one (since you were unable to upgrade the firmware...)
macourteau
Macourteau
Je vis aussi à Montréal et j'ai la DJ Console que j'aime bien.
Je ne fais pas de scratch et je ne veux donc pas faire le upgrade de 1.09 vers 2.0. Je me demandais si il serait possible d'obtenir tes dll d'effets spéciaux et le DB updater. Tes effets semblent vraiment super! --@--.--
Moderated by Lady Cameron
Sorry bjbladerunner no email address is allowed from a demo user
Désolé bjbladerunner, mais les effets sont disponibles pour les utilisateurs de la version full seulement (et le programme DB updater, c'est pour la version 2.0 et 2.01 seulement...)
macourteau
Macouteau es-tu allé faire réparer ta console? J'ai eu un seul incident ou une toune c'est mis à spinée. En touchant le jog wheel tout est redevenu normal. J'ai tout les derniers upgrade. Est-ce que tu crois que je devrais allé pour un checkup anyway?
Non je ne suis pas encore allé (par manque de temps), mais j'ai justement le même problème, alors je vais y aller dès que je trouves le temps.
macourteau
