Since VDJ 5, I have noticed that I am unable to use the MK2 jog wheels to scratch. Instead, they only seem to slow or speed the track while playing. I have to pause the track in order to get any kind of "rewind" or "fast forward" scrub type action.
I installed the MK2 Mapper from your downloads section way back when, but don't use it (as it seemed to conflict with other VDJ settings). So maybe that's the problem? Either way, how do I uninstall the "mapper"? Does anyone else have this scratch problem?
Posted Tue 21 Aug 07 @ 11:09 pm
Okay, so I found how to uninstall DJC Mapper. Hopefully this works.
https://virtualdj.com/forums/48798/Hardware_Technical_Support/Can_I_uninstall_the_DJC_Mapper_.html?highlight=uninstall%20mapper
Posted Tue 21 Aug 07 @ 11:36 pm
