Forum: Music discussion
Topic: how to scratch and make sound effect?
guys hi. i'm jackpro41
how u guys make the disc scratch till like this.
example a guy was talking ''yeah !!!'' this word
how to make it to ''ye ye ye ye yeah ............!!!!!!!!!!!''?
any tips or trick can teach?
Posted Tue 21 Aug 07 @ 5:00 pm
thx ya man
you can't really achieve good scratching without external components, but it's well worth a try! Before the 'yeah' set a cue point, and then play it but right before, hold it with the mouse, and then try scratching a little bit and let it go when you feel like, just a suggestion.
ya,i agree to u too.
anyway thx for the suggestion
really good ;) i wanna learn it quickly man :D but before this i must buy a turntable, i think :D isn't it?
does anyone know where i can download sound effects the type that is frequently used for hip hop and reggae music.
@mrosemond
More then 1 post is unecessary. If you are really desperate to find samples why not do a google search for battle records where you can buy some and get hundred of different samples.
not sure where you can download them although you can make your own samples using a wave editor and just cut out the section you want and use that as a sample.
