Topic: VirtualDJ 5 - New Features user guide - Page: 2
FlavioPiu wrote :
Please ?
This new version have support to M-AUDIO Xponent ????
yes but you need to map it .
which is very easy ,
This is a thread about the manual -- not to ask what is supported -- Ask those in a different thread please.
Also, just to explain the controllers - if they are MIDI then there is support. There is only 1 NEW Natively support controller in VDJ v5. That controller is the ION iCUE, which is a trimmed down version of the Numark TotalControl. MIDI was improved upon in VDJ v5, so those that were having issues before with some MIDI settings should improvement. If not, please report those issues in the PC Software or Hardware Troubleshooting threads.
question about Midi..
Does version 5 support more than the 1st parameter for Midi?
For instance in 4.3 you could use your midi device to control the speed that the video cube spins (1st parameter), BUT COULD NOT control the size, or direction (other parameters).
Hope this makes sense.
thanks,
B
@Hoffman:
YES!
but it isn't really related to midi, but to actions that can be used as shortcuts, including midi.
use actions: video_fx_param(), video_fx_param_2(), ..., video_fx_param_5()
And it is mentioned in the Manual in the Shortcuts section.
Remember if you can create a Keyboard Shortcut -- you can assign it to a MIDI control as well in the MIDI config.
gotcha- so it wasn't a midi thing, it was a shortcut path thing.
cool!
Thanks,
B
Hey guys. Really trying to get this manual together, but there's something going wrong with my laptop and Adobe. I don't suppose any kind soul in VDJ land could email it onto me as a word doc or something please?
Cheers...and keep spinnin'...(",)
P
try foxit reader it's free pdf reader and faster than adobe native reader
piacere sono nuovo ovvero italyan quindi anke se voi non mi capirete ne o cdapirò voi userò internet per tradurre la vostra lingua
Help plez...My cdg files from zip files is not loading in VDJ5, the mp3 does but no video???? is there a cdg decoder....I've been searching the past hour and 1/2 in the forum...and have gone thru vdj5 manual but no luck....
thanks much
GREAT JOB with VDJ5...so much better than PCDJ!!!! you guys rock!!!!!!!!!
MARK ALLEN
PLEASE post this in it's own thread this is a place to discuss the manual not report problems.
Thank for guide great help just trying to work out the animation in video effects thing lol
Will the BCD 3000 of behringer be a native on the Virtual DJ 5?
