Topic: What would happen if..
...i connected 4 x 8-Ohm speakers to a two Channel Amp (with the option of Jack or Speakon connections for each channel)
I know the impedance would drop to 4 Ohms if the 2 speakers were daisychained onto each channel.
But what If i connected Two speakers via Jack and the other two via Speakon, would the speakers all be running at 4ohms, or would the AMP default to just sending the signal to either Jack or Speakon rather than both simaltaneously.
Hope i made sense.
Posted Mon 13 Aug 07 @ 9:22 pm
Most likely they are wired in parallel internally, which would give you a 4 Ohm load on each side.
